TIN HAT READY??
	yes you can and no it wont cause any damage it's not to everyones taste but neither is "marmite" been doing the same thing for the last 4 years since bringing the van home from the dealers and thinking how crap the alko hitch was (aks 1300 model) first job before using the van again "fit the scott brackets"  we have just got back today from a 3week jaunt around the south west and midlands covering 1700miles in total with probably the most stable outfit I have towed with in over 40years, nothing bothers it it never moves off line even in the gale force winds we had first week away, some say it will damage the car?/ B*.S*. had the tow bar off last year for rear end repairs everything perfect replaced bar with new bolts nuts ect,
	to answer some of Damians points."
	1. Its big, heavy and needs to be stored when not in use.
	A. so does a wheel clamp but we all carry one, as for storage thats what the big box on the front of the van is for!!
	2. It affects the braking of the van as it has pressure on the A frame and slows the reaction of the drawbar, which slows the application of the brakes.
	A. yes it does and it also resists the damper return stopping the thump in the back of car giving a smoother transfer of energy rather like a brandnew damper would do so what is so bad about that? abolute braking ie downhill is not affected
3. It is putting an extra load on the towball, above the noseweight.
	A, it lowers the noseweight not increases it, yes  it's true there is some extra load but not on the ball just the "bracket" considering all the forces applied to the towbar during use the extra bit made by the blade is miniscule
	4. The blade can ,and does, easily slip out of its cup on uneven roads.
	A, not so if it is fitted and adjusted correctly I have never had one disengage in 30 years of using one
Just ask if he does not think the ball acting built in stabiliser is up to the job, is he happy with just a diagonal seat belt, or will he now fit a full harness seat restraint system?
	Can't answer that one exept I have allways believed that belt AND braces was perferable to losing ones trousers
