C250 Thetford
Oct 17, 2010
1,291
536
19,435
Hi
Been looking for the a replacement drain down pipe that replaced some of the original piping from the flush pump, so that the pump can be drained down completely to prevent it freezing???
I'll stop now before my question turns into gobbledigooch.
Has anyone got a link???
Jan 19, 2002
1,674
516
Agree with Buckman above as I had a freebie mod kit from Thetford. You can find the serial number for your loo and then Thetford might still replace for you.
4,039
During Winter, i put a bit of windscreen wash Into the top up ( The type that goes down to minus 15c ) Never hurt the seals so far. Also Anti freeze in the shower drain.
1,291
536
19,435
As I do, about a ltr, then run the pump until it reaches the bowl. Only just been told about this mod, and being at the O.F stage my memories going.
4,687
To tell you the truth went onto thire web site couldn't find it didn't bother. Thanks.
You need to phone or email them. No manufacturer is going to admit that there is an issue with their product. Bad for image.
Reactions: DaveA1
Jun 17, 2011
826
27
Worth doing. I lost the loo overnight when i fused it on arrival, Sunday pm due to frost. Current cassette came with pipe attached. Unhook it pull plug, drain. Easy. They now fit an automatic fuse so those 49 fuses I've got left..........
Reactions: DaveA1
