cadac help
Could someone advise me on what I need to buy to fit my new cadac BBQ to my external gas point on my van? IS it necessary to have a regulato between the bbq and the van connection? I have a 2005 Swift that looks like the hose will need a male fitting to connect to the female fitting on the van? Help! Bit lost. Thanks.
If it is the same as mine (and I think they all are) you will need 2m (legal or advised maximum)of correct type pipe, 2 jubilee clips and the adaptor - mine came with the van.
You can get all of this from most caravan shops.
Cheers Gary, by 'adaptor' do you mean the piece that connects the hose to the caravan gas point? Thanks.
Yes... he does and they cost a few bob from any caravan accessory shop.
Yes as SD says.
It is metal about 2 in long, the pipe pushes on one end and the other end clicks into the BBQ point.
The shop should know exactly what you are after.
I bought one myself about 6 months back if it would have been anymore than
