Camber on one wheel
I have a 2002 Compass Rallye 482, was away last weekend and noticed that the offside wheel had slight negative camber but the nearside one is vertical. I have checked the obvious, ie loose nuts and signs of damage, but can find nothing untoward. The van tows perfectly with no vibration or wobble,can anyone suggest the reason for this and how to fix it.
Thanks Jim.
3,534
Hello Jim,
I an certain that both wheels should have identical characteristics, If there is a difference, then something must have changed in the suspension or its mountings.
This is not a DIY job, get a caravan dealer who should be able to tell you what has happened, and most likely also be able to quote for repairs.
I do not recommend towing it until it has been fully diagnosed.
