Can we really believe (AND RELY ON) what we read in Practical Caravan Magazine ?
Aug 4, 2004
4,343
Prof John L said:
This thread demonstrates one of the reasons why I suggest the 85% guidance is so imprecise and flawed. If the main key variable (kerbweight) cannot be consistently ascertained, then the output of any calculations based on it will also be flawed. - But in the absence of any other agreed method it is still better than nothing.
When the 85% guideline was thought up, wasn't one of the reasons because cars in those days had a much lower bhp even though they were heavier? I think the UK must be the only country with this guideline?
I can well remember when I started out with my 1st caravan purchased from selston caravans in Nott's, in the early 70s, there was posters in the vans with the information : 4 berth towable by a 1600cc car etc.
In our case we purchased a sprite musketeer, vintage late 50s, glass windows, steel chassis, pull down double bed in the rear complete with mattress, and a 2" coupling, not a clue what it weighed but it was a heavy old beast, and displayed in the window "suitable for a 1600cc car" at the time I had a Hilman super minx with a 1700cc engine, it pulled it just.......................................lol
4,396
Its not clear when the guidelines were introduced, nor the reason why, or the basis of the actual figure, but back in the 1970's there were few details published of the vehicles capabilities regards towing, so a guidance was a sensible approach. It has apparently been revised at some point, but the factual and technical basis of the recommendation has never been published.
What has changed is the EU's type approval system for cars, where there is now repeatable test evidence to support car manufacturers specifications for towing capacity of ideal trailers.
Caravans are not ideal trailers, so it makes sense to apply some sort of handicap which represents the deviation a caravans towing characteristics from the ideal trailer, and then relate that to the car manufactures specified maximum towing limit.
Not sure if this has any bearing on the 85% guideline, but back when I had my 1st caravan in 1971 the speed limit for a car towing a caravan was 40mph, I think it was around the late 70s early 80s the speed limit was increased to 50 mph. The criteria for the new limit was that you had to display a 50 sticker to the rear of the caravan and also the weight of the caravan had to be displayed on the drawbar of the caravan and also on the rear of the towing vehicle, if not you were restricted to 40 mph.
you could buy sheets of self adhesive numbers witl sticky black boxes that you put the numbers in to, could it have been that if you we're below 85% of the cars kerweight that you could tow at the new speed limit ??? Any one out there with a better memory than mine, I know I'm correct with the advent of the new 50 mph limit and displaying the weights, but that's when my memory starts to cloud. :(
Jul 28, 2008
752
21
Hi Al,
It was the early 70's that the 50mph was introduced. You're quite right in that a 50 sticker had to be put on the rear of the caravan. The gross-weight of the caravan had to be placed "in a conspicuous place" on the caravan, and also the kerbside weight of the towing vehicle "displayed in a conspicuous place" on that. The only real criteria other than the above was that the gross weight of the caravan must not exceed the kerbside weight of the car.
Halcion days when things were simple!
9,331
Two things strike me about this discussion, firstly its not always feasible to look at your V5 as it doesn't come along until your new car is delivered. Alright if your buying a used car, but with a new one you'd have to visit a dealer and ask to see a similar spec car to the one you plan to buy and then ask to see its V5. Secondly my caravan owners manual quotes a tolerance of +- 5% on MIRO against the specified figure. That's 50kg either way for each 1000kg of MIRO. so your van could be the light one or the heavy one. But the MTPLM doesn't change so you could have increased or reduced payload. But of course your van MIRO might change by that amount depending on ambient conditions. I don't know wether the more modern vans have this weight tolerance stated or perhaps the newer build materials are less sensitive to humidity/ moisture variations.
I have always done my own research re tow car and van compatibility ever since when I bought our first van and the dealer said that my BX 16 estate would be absolutely fine. He wasn't aware of the BX weight or max tow weight, which were not suitable for the van, but unbeknown to him we had a Mondeo which was compatible!
chenzhen
BANNED
May 19, 2016
99
"The word vintage, used to describe dresses and clothing, is a broad term that is generally used to refer to clothing that originates from a past era. In general, clothing that dates earlier than the 1920s, is considered to be antique. Whereas clothing and dresses that have emerged after the 1920s, up to the 1980s and 90s, is considered to be vintage. Retro, or vintage style, usually refers to clothing that is an imitation of the style of a previous era.
A range of vintage style clothing that is hugely popular today, are the fifties dresses. The enduring popularity of these dresses, might be because that was the time women's clothing made significant strides, as it was after the second World War and many restrictions had been lifted and designers had more freedom and materials available to create beautiful women's fashion ranges.
Some of the popular dress styles that have enjoyed a timeless appeal have included the Ophelia dress, floral tea dresses, Audrey Hepburn style dresses, the figure hugging Lindy Bop dresses and dresses made famous by Grace Kelly and many classic Hollywood stars. Even today, young women are choosing vintage style dresses for their special occasions such as a ball, prom night, and other formal parties, because they have a definite charm and elegance and have been designed to enhance a woman's shape and beauty."
fake oakleys
michael kors uk
cheap ray bans
rolex watches for sale
nike free flyknit 5.0
ugg boots
coach outlet online
yeezy boost 350 white
michael kors bags
air max 90 white
ralph lauren outlet
louis vuitton bags
converse sale
coach factory outlet
adidas shoes
nike free flyknit 3.0
burberry outlet
nike air force
cheap ray-ban sunglasses outlet
tory burch shoes
nike tn pas cher
chaussure louboutin
adidas nmd runner
louis vuitton handbags
skechers outlet
oakley sunglasses cheap
cheap jordan shoes
ray bans
adidas nmd black
reebok classic
adidas trainers
vans store
nike cortez white
pandora charms
air max 90
adidas shoes
fitflops shoes
timberland uk
pandora charms uk
armani exchange
burberry bags
under armour
louis vuitton outlet stores
oakley sunglasses wholesale
pandora jewelry outlet
cheap basketball shoes
ferragamo
ralph lauren
pandora rings
toms outlet
michael kors outlet online
prada sunglasses wholesale
cheap ray bans
www.coachfactory.com
cheap air jordans
michael kors handbags
valentino
michael kors outlet clearance
michael kors outlet
ugg boots
ralph lauren
ghd
mizuno running shoes
nike air force black
cheap jordans
nike free run flyknit
cheap ray bans
sac longchamp
kate spade outlet
cheap ray ban outlet
ray bans
true religion jeans
babyliss hair dryer
michael kors bags
true religion outlet
reebok outlet store
ray bans
nike trainers
polo outlet
fitflops
adidas superstars
true religion outlet store
kate spade uk
discount nike air max
ray ban sunglasses outlet
jordan pas cher
levis 511
nike huarache
omega speedmaster
christian louboutin uk
michael kors outlet store
tiffany jewelry outlet
polo ralph lauren men
adidas supercolor pink
rolex replica watches
ray ban outlet store online
cheap nike air max
coach outlet store online clearances
tory burch flats
hollister hoodies
nike cortez shoes
louis vuitton outlet online
hollister hoodies
pandora jewelry
louboutin outlet
coach factory outlet online
adidas pure boost black
designer handbags wholesale
yeezy boost 750
true religion
kate spade outlet online
tiffany uk
lebron james shoes 12
red bottoms outlet online
cheap jordan shoes
jordans
gucci borse
gucci handbags outlet
ray ban sunglasses sale
lacoste shoes
bottega veneta shoes
michale kors uk
ray ban sunglasses discount
louis vuitton uk
cheap ray ban sunglasses
longchamp outlet
micahel kors
adidas superstar white
air max
cheap nfl jerseys
burberry outlet
christian louboutin outlet
hollister clothing store
oakley sunglasses outlet
ralph lauren
nike blazer
michael kors canada
birkenstock sale
cheap ray bans
white converse
louboutin pas cher
jimmy choo
ed hardy uk
bottega veneta sale
north face outlet
nike air max 95
burberry sale
abercrombie and fitch outlet
hollister kids
louis vuitton purse
supra outlet
nike huarache black
nmd adidas
asics running shoes
lacoste polo shirts
jordan shoes
michael kors canada
abercrombie & fitch
coach outlet online
tiffany jewelry
burberry outlet canada
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
ralph lauren outlet online
canada goose outlet
mlb jerseys wholesale
vans outlet store
birkenstock sale
coach purses on sale
ferragamo outlet
valentino bags
rolex submariner
mont blanc outlet
hollister co
nike air force
the north face outlet
armani outlet
tiffany and co outlet
michael kors handbgas
cheap oakleys
north face jackets
dior sunglasses 2016
coach outlet online
north face uk
kate spade bags
polo ralph lauren outlet
ray ban outlet online
adidas nmd uk
ghd hair dryer
jordan shoes
hollister uk
michael kors uk
buy red bottoms
nike roshe run
kate spade outlet
toms shoes
cheap oakleys
louis vuitton factory outlet
polo ralph lauren outlet online
puma outlet
true religion uk
chi flat iron
fitflops sale clearance
true religion jeans outlet
michael kors outlet canada
michael kors outlet
oakley sunglasses
instyler max
true religion jeans
fitflops
fitflops shoes
polo ralph lauren
pandora sale
michael kors outlet stores
hermes outlet
cheap oakley sunglasses
nhl jerseys wholesale
toms outlet
longchamp uk
timberland shoes
asics gel kayano
michael kors outlet
ed hardy
polo ralph lauren
versace sunglasses wholesale
louis vuitton borse
kate spade handbags
new balance shoes
versace sunglasses
birkenstock outlet
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
michael kors bags
birkenstocks
nike air max 90
timberland boots for men
kobe bryant shoes
adidas shoes
birkenstock shoes
christian louboutin shoes
under armour outlet store
rolex daytona
michael kors outlet
abercrombie outlet
birkenstock uk
cartier
omega
polo ralph lauren
true religion sale
burberry outlet stores
nike shoes for cheap
nike store uk
sac longchamp pliage
nike force 1
ecco outlet
coach outlet online
louboutin shoes
canada goose jackets
nike free runs
reebok
converse outlet
coach outlet online
stephen curry basketball shoes
hollister kids
jimmy choo outlet store
nike air max 90
hermes belt
louboutin shoes
supra store
stan smith adidas
toms outlet
rolex watches uk
wholesale nike shoes
gucci outlet online
yeezy boost 350
nike free 5.0
cheap nfl jerseys
reebok shoes
coach outlet online
coach outlet store
tiffany and co jewelry
timberland shoes
ray ban outlet
timberland boots on sale
cartier love ring
white converse
louis vuitton purse
air max 90
ralph lauren pas cher
air jordan shoes
prada handbags
michael kors canada
holliste sale
adidas gazelle
nike flyknit racer
oakley sunglasses uk
yeezy boost 350 balck
lebron james shoes 2016
ralph lauren outlet
nike running shoes
kobe 11
nba jerseys wholesale
coach outlet store
michael kors handbags outlet
hollister clothing
louis vuitton pas cher
ralph lauren sale clearance
cheap oakley sunglasses outlet
"One of the most popular, but simple fifties dresses, is the petticoat. This was designed to be flattering to a lady's shape and also, to enhance the dress she was wearing over it. Petticoats made of silk and woollen materials were initially introduced for women to wear under the main dress, as they provided warmth and would enhance women's busts. The classic petticoat then became shorter and lacy petticoats became the fashion, as they delicately accentuated the dresses that were worn over them, such as the Ophelia dress.
Vintage style dresses UK are available in a wide variety of sizes from vintage clothing shops, textile fairs, auctions, flea markets, estate sales, antique markets, garage sales and collectable fairs. However, there is always the risk with buying genuine vintage clothing, that the sizes may not match current clothing sizes. But there are a number of special boutiques online, who specialise in designing and creating vintage clothing to order. They can take your specific measurements and produce an outfit that will be tailor made and fit you perfectly"
g;ldfhk
