- Jul 18, 2017
- 16,925
- 5,505
- 50,935
Is that padded? Looks nice and comfy.Not technical but this is what I purchased
Not all caravans have a battery fuse..Thanks for your replies and I should of mentioned that my van is a 2007 Lunar Lexon EW Twin Axle. I do have a mover which was fitted a couple of years ago and I can see the fuse for this which is screwed down inside a small black box , so no problem there and the mover is wired straight into battery so still operates, I have a feeling that i will find the fuse under the battery box but it does seems strange that any right minded company would do this but perhaps Lunar are the exception. I am pretty sure its not in battery box as I have a good idea of where everything is except this fuse. Frankly I never use the van on a site without 230v and so I guess it will work OK but not sure if running like this is detrimental to other parts of the system. Bearing in mind last year when I was away the charger blew up and everything failed . Bought new battery and fitted an external charger under seat into the battery box and charged it up that way.
Maybe if you had been inquiring for the chest in front for Lunars of that year, you would have had a better result. The same chest would have been used across most of the Lunar range for the year in question.While I have your attention does anybody know where I can find a table top for my Lunar Lexon EW. My one came loose and has a chip out of it and I want to replace. Tried loads of breakers but they do not seem to hold many table tops which is odd as most vans broken would have a table . My one is a creamy colour with a marble effect . Do not have picture but can get one later.
