Cant find fuse from battery to PDU
Thanks for your replies and I should of mentioned that my van is a 2007 Lunar Lexon EW Twin Axle. I do have a mover which was fitted a couple of years ago and I can see the fuse for this which is screwed down inside a small black box , so no problem there and the mover is wired straight into battery so still operates, I have a feeling that i will find the fuse under the battery box but it does seems strange that any right minded company would do this but perhaps Lunar are the exception. I am pretty sure its not in battery box as I have a good idea of where everything is except this fuse. Frankly I never use the van on a site without 230v and so I guess it will work OK but not sure if running like this is detrimental to other parts of the system. Bearing in mind last year when I was away the charger blew up and everything failed . Bought new battery and fitted an external charger under seat into the battery box and charged it up that way.
Not all caravans have a battery fuse..
Really odd when I first got on the forum tonight I saw two things . First somebody had said my new seat looks comfortable and is it padded and the other said Not all caravans have battery fuses but now I cannot find either of these and who wrote them - odd. However the person who said not all vans have a battery fuse was correct . MY problem was just a simple fuse in the PDU, the third one down for the battery but i had replaced all the fuses having purchased a large box full of all ratings.. I also removed all of them and held up to light to check but all seemed OK. The main point is that the fuse was wrong rating only 10amp and should have been 15amp. I guess I only replaced like for like and did not check rating. The PDU is so awkwardly placed that you cannot see the fuse ratings beside the fuses and they are also worn away so not easy to read. So i should have checked handbook but lesson learnt and not too expensive.
By the way the seat is padded and more comfortable than my settee at home. It is also quite high so easy to get in and out. Thanks for the help given to resolve my issue.
Sounds much like my sister in laws Adria
Half of the 12v electrics didn't work, caused by a combination of wrongly fitted(!) and blown fuses (wrong rating). None of the fuses appeared blown either, but back probing them told a different story.
While I have your attention does anybody know where I can find a table top for my Lunar Lexon EW. My one came loose and has a chip out of it and I want to replace. Tried loads of breakers but they do not seem to hold many table tops which is odd as most vans broken would have a table . My one is a creamy colour with a marble effect . Do not have picture but can get one later.
Maybe if you had been inquiring for the chest in front for Lunars of that year, you would have had a better result. The same chest would have been used across most of the Lunar range for the year in question.
