- Feb 3, 2008
- 3,790
- 0
- 0
Had another good look today and decided replacing the tap is 'do-able' by first removing the sink.
Dustydog said:Sounds like you have a plan :cheer:
Look forward to seeing your You Tube posting B)
WoodlandsCamper said:![]()
Whilst checking the size of the fixing nut today I realized that, although the nut is brass, the threaded part is actually chromed plastic. I therefore think that the wobbly tap pillar in the van is caused by the upper threaded part fracturing at the shoulder, possibly caused by a knock to the pillar or stress from original over-tightening.Just need to get back over to the van in storage to work out how to replace it.
WoodlandsCamper said:.........The hole in the shank doesn't seem to be for any purpose.
WoodlandsCamper said:We Woosied out of touching any pipe connections (as we touched some radiator taps at home this week and now have a leak), replaced the sink and have put the van back in storage.If needs be in the future then I will replace the tap in the van.
I think a thin piece of card from a cereal packet or some electrical tap might stop the wobble.
Edit - forgot to mention that on the existing tap the pre-formed tails are about 3 foot long, whereas the tails on the replacement tap are only 1 foot long and exchange would therefore be needed. There was no guarantee that the tails were interchangeable at the tap end.
Dustydog said:I suspect the pipe to tap connections are the same size. Have you thought about another mid joint?
Maybe you could use the WoosieTask Force at the next Fest![]()
