caravan awnings
hi been away in the van all ok exept for the awning ,wrong size too small .the awning that came with the van is a trio mexico theres a 750 label on it that i asume is the size .on the avondale specs it says the awning size need to be 828cm .now ive found another awning that has trio sport 825 on it , the length in centimeters is 800 to 849 ,i was just wondering if anybody could give me some idea if this awning will be ok to fit the van . thanks graham
Why not put your caravan on level ground and run a piece of string from the ground right round your awning rail to the ground at the opposite end of the awning rail, measurement off and this will give you th esize of the awning you require,
just measured the van floor to floor and it comes out at 790 cm give or take a centimetre or two ,so 800 to 849 should be ok . at least it wont be too small .thanks
