Caravan door blind
It would help to know the make, model, and year of your van, and if you can see it the make of door (probably Hartal - most are.)
If it is Hartal the panel on the door around the window is easily removed by popping the clips out at the bottom. The blind comes out with the panel.
Do a bit of Googling or You-Tubing - there are dozens of videos on how to do that sort of thing. The spring return on the pull-down blind in the door window of our Unicorn S4 Seville became detached. I found a video of how to do it, dug out some superglue, and followed the instructions to the letter - and it worked!!
Our last caravan needed a new door blind and managed to get one on ebay, it needed encouragement to be put in and luckily we had a good caravan engineer who was able to put it in, If you are proficient at doing these kinds of jobs then good luck but otherwise try to find someone who is able to do it for you.
The Lunar will have a Hartal door so you should follow the you tube videos as virtually all caravans have these although there are different models which might mean a bit of variation, but if you check the videos you should find the correct one. .
