Caravan First Service
Jul 4, 2006
14
Hi
The caravan I bought from Barrons will be coming up for its first service soon.
I seem to recall that I have to have it done by Barrons to keep up the warranty.
Can anyone tell me what work is done on a typical service as I have seen large variations in price ie £100 to £250.
Not sure what Barrons will charge at this stage.
My caravan is a 2006 Sprite Major 5. (Firebrand 512)
Regards
Andy
Copied From UKCS
ice check list
Message posted by Rizzo on 25/7/2005 at 12:40pm
View Profile Quote Tell a friend Report Post
Rizzo
Diamond Member
Outfit: Ace Prestige 55 & Mondeo 2l TCDi
Gallery Images: 3
Thought this would be of interest to caravan owners:
Hitch Head & Gaitor
Check & Grease
Hitch Head Stabiliser
Check & De-grease
Hitch Damper
Check
Drawbar
Check & Grease
Brakeaway Cable
Check
6
Jockey Wheel & Clamp
Check & Grease
7
Chassis
Check
8
Axle
Check
9
Corner Steadies
Check & Grease
10
Wheel Carrier
Check & Grease
11
Suspension
Check
12
Shock Absorbers
Check
13
Tyres & Tyre Pressures (Manuf / NCC)
Check
14
Spare Tyre
Check
15
Brake Rod, Linkages & Cables
Adjust & Grease
16
Hubs, Bearings & Oil Seals
Inpect
17
Brake Shoes
Inspect & Clean
18
Hub Nuts Torqued
Torque
19
Handbrake Performance
Check & Grease
20
Braking System (forward / reverse)
Check & Adjust
21
Exterior Locks & Hinges
Check & Lubricate
22
Grab Handle Security
Check
23
12N&12S Plugs, Cables and Systems
Check (New / Old)
24
Roadlights, Wiring, Reflectors
Check
25
Floor Delamination
Check
26
Damp Test
Report
27
Water Pump (Carver / Whale / Surflo)
Test
28
Water Inlet Socket
Test
29
Water Filter (Carver / Whale)
Fitted in Situ. Yes / No
30
Hot & Cold Water Pipes
Test
31
Waste Water Pipes
Test
32
Taps
Test
33
Microswitches / Pressure Switch
Test
34
On-Board Tank
Test
35
Toilet Pump & Flush Mechanism
Test
36
12v DC System Wiring & Fuses
Check
37
12v Lights inc Awning Light
Test
38
Leisure Battery & Load Test
Check
39
Mains Inlet Socket
Test
40
Mains 240v Wiring & Fuses
Check
41
Mains Sockets (internal / external)
Test
42
Mains R.C.D Load Test
Test
43
Transformer/Charger Rate
Check
44
Gas System & Pipework
Test for Leaks
45
Gas Hose
Replace
46
Water Heater Gas / 240v
Test
47
Hob, Grill & Oven
Test
48
Fridge (Electro / Thetf ) Gas / 240v / 12v
Test
49
Space Heater
Test
50
Carver Fanmaster
Test
51
Truma Ultra Heat
Test
52
Blown Air Ducting & Vents
Check
53
Windows & Fittings
Check
54
Blind & Flyscreens
Check
55
Drawers, Cupboards & Lockers
Check
56
Furniture Hinges, Stays & Catches
Check
57
Rooflights, Remi & Heki
Check
58
Smoke Alarm Battery in Yes / No
Test
59
All Internal Vents
Check
60
External door Seals
Check
4,457
Hello Andrew,
You have two types of warranty, one is through the sale of goods act and protects your statutory rights. This one does not require the service work to be carried out by a specific dealer, see
http://www.dti.gov.uk/consumers/index.html
The second is the manufactures warranty, which is in addition to your statutory rights. Here the manufacturer tries to tie you to their network of dealers, but you may be able to have the service work carried out by a competent dealer other than one from the manufactures stable.
Check with the manufacture, You may be able to select another dealer altogether provided they have been assessed and accredited by Jones Venning, who seem to be the 'independent work shop assessors'.
http://www.jones-vening.co.uk./index.php
Contact your manufacture and see if such a change is acceptable and will not affect your manufactures warranty
Hi Andrew, our van was serviced by Barrons late November and the jobsheet I have from that service matches what John has posted. Barrons have fixed costs for single and twin axles, I think our single axle was around
Aug 12, 2005
47
Hi, we purchased our first new van in August, a Bailey 550/6 Ranger. We are not impressed with the level of service received, i.e. waiting weeks on end and constantly chasing them when ordering small extras we needed, and because of this we want to go elsewhere for the service but are led to believe we have to take it back to where it was bought from. But my argument is what would happen if we moved to the other side of the country, would we have to travel all the way back. Surely we can take it to an authorised Bailey dealer? can anyone shed any light on this situation.
May 4, 2005
2,622
Looking at the check list makes me think we are being over charged for servicing. I've had 8 vans , 3 of them new and never had them serviced. I do all the checks myself before each trip and the only time I've had a fault Barrons sent me the part,a light fitting, at cost, to fix myself. To take my 'van to the supplying dealer for sevicing is out of the question due to distance and I'm happy to have ,effectively, a one year warranty (before the first sevice is due) as any faults ,if any, should happen in that period.
The lack of history has never been an issue when coming to PX either generally when they are three years old.
Brian (",)
4,457
Hello Craig,
There are two types of answer to your question depending on what the specific problem is.
If the product is not fit for purpose, or is not of merchantable quality, the remedy lies entirely with the seller. These conditions are covered by your statutory rights as defined in the sale of goods acts.
see: http://www.dti.gov.uk/consumers/index.html
These statutory rights exist exclusively between you and your seller. These are set in law and cannot be changed. Please note that the seller is the organisation to which you pay your money, so if you have used a finance house then you deal with them.
The second area is the Manufacture's guarantee; These usually afford extended cover or special terms defined in the small print. Here the manufacturer offers the guarantee, and if you agree to it, it forms a part of the contract of sale. If you wish to retain your rights to this guarantee, you must abide the limitations and stipulations made in the contract. Things like service intervals or the routine inspection of certain parts. Failure to keep to the agreed schedule can void part or the whole of the manufactures guarantee.
Frequently the manufacture will stipulate that service work should be carried out by one of their dealers. This is a grey area, and similar limitations in the automotive field have been judged as unfair through the courts. Provided the work is carried out to the standard required by the manufacture or accepted industry standards, then, it may be performed by competent service centres not controlled or franchised by the manufacture.
Jones Venning offers independent assessments of the competencies of caravan workshops, and in general any of their approved workshops should be able to carry out the basic caravan servicing on any make of caravan.
For clarity, you should contact your manufacture to seek permission for service work to be carried out by a JV approved workshop near you.
If the manufacture refuses, then you should seek professional advice to challenge the terms of your contact. (Trading Standards, and a Solicitor or CAB)
4,457
Hello again Craig,
I'm sorry I did not answer an important part of your question:-
If the caravan contravenes the sale of goods acts regulations, then your statutory rights are exclusively with the original seller, and you have to deal with them for remedy under the act.
You may be able to negotiate with the seller to have repairs carried out elsewhere, but that has to be agreed with the seller and is a separate contract.
Most manufactures extended guarantees allows for work to be carried out at approved dealers. See your documentation for details of participating dealers, of contact the manufacture for more information.
