Caravan front and rear roof straps
May 3, 2023
78
50
585
hi all has anyone resealed the roof straps on the caravan both front and rear. Iwas thing of sikka flex 512 then rolling on the white self adhesive bitumous water proof tape. Its about 4 incheswideThere is a short video on you tube looks good and comprehensivejob.
regards caravan john
78
50
585
regards john
Hi hutch .have you done the same task pal?
Regards caravan john.
May 2, 2020
279
111
4,735
Hi
I have resealed both on my own caravan and others, I used sikaflex 512 or the newer version of 522 it is a reasonably easy job but quite labour intensive as you need to remove ALL the old sealant and clean all surfaces with white spirit and then methalated spirit before applying new sealant, also if the strap has leaked for a while the roof rafter could be rotted so may need renewing, as for using a tape over the strap may be OK but if I saw a caravan with tape on the roof they are trying to hide a problem that has already happened
Gra
May 3, 2023
78
50
585
Hi
Gra
Hibthanks gra easy job but to.me it's belt andbraces to do this as it's a pinch point for leakages particular with pooling water.
May 3, 2023
78
50
585
Hi gra.
Are you saying just use sikkafex pal iam with that one. Do you just sikka flex will suffice.
4,600
Hi hutch,have you done this task.
Hi John, I still haven't gotten round to doing my Coachman. This year's excuse has been detached Retina, and now Carpal tunnel Syndrome.
At year 3 I had a new rear panel replaced by Coachman in Hull, and they resealed all the roof joints at that time. So far it is still a below 15% damp caravan.
Ps, typing this with my special tipless compression gloves on.
May 3, 2023
78
50
585
Hi gra.
Are you saying just use sikkafex pal iam with that one. Do you think just sikka flex will suffice.
Hi hutch I went in for a routine knee op and ended up have a stroke during surgery I nearly died but I am battling on keepnhgoing pal you will get there. I will get back caravaning.may be a while but I will do it
5,297
Carpal tunnel syndrome is not pleasant. I had the op done in my early forties and was supposed to work one handed for nearly 6 months. Luckily it was repairing TVs so only had to get someone to lift them onto the bench for me.
4,600
I am being bounced around from Physio, to Rheumatology and now to Neurology, I cannot grip small items like Screwdrivers etc, I am building a model Sopwith Camel and a radio controlled car, all on hold now.
So trying to grip a roller to seal down the tape for roof joints would be almost impossible. I found this tape. Actual roof lock tape is mega expensive, but probably worth it.
5,297
https://www.amazon.co.uk/CANOPUS
I was lucky as saw the doctor and two weeks later the op and home the same day. I have an interest in the Sopwith Camel. Is it a large model and just an Airfix model? Quite a plane in its day.
9,158
I was considering Rooflock, or Eternabond, both of which have an excellent reputation albeit not cheap. In the end my Swift dealer gave me some of the OEM white seal tape. That did the job fir 6 months whilst I waited for the new rear panel to be fitted.
4,600
It is a 18 inch wingspan, Balsa model, rubber powered. And tissue covered.
An on going project.
78
50
585
Hi buck mam that's the tape I have ready to go.
Regards caravan john .
