Caravan lights
Feb 15, 2006
195
Hi guys,
I need your help on the caravan lights the ones on the outside.
The offside lights aint working the indicators are but the little white lights at the front arnt and niether are the brake lights.
Ive checked the fuses and i think it may be the plug socket on the car.
Any ideas?
M.H.
Feb 3, 2005
532
Clean the plug and socket terminals, as Val said, then check all the live and earth sockets/pins with a meter which you can buy cheaply in a DIY shop or somewhere like Maplins. Otherwise make up a test light with a bulb and two pieces of electrical wire. This will tell you whether the problem is in the car or 'van.
Hope this helps, but if not post again.
Keith
Sep 11, 2009
14
If you google 7 pin plug cleaner it will bring up a tool for cleaning both male and female cleaners.They are seven little wire brushs have used them before and they work really well hope this helps
