And caravans have a much thinner coat of paint than carsBe aware some polishes are abrasive,if you caravan is clean and free from any blemishes then use a good quality wax, I've used Armorall Speed wax(contains carnuaba wax). I've always been satisfied with the results and easy to apply
Same here as Birdman and Dusty dog.Never polished a Caravan in 50 years, but use a good shampoo. Recent years washed with Fenwicks and then Finnish with Fenwicks Bobbydazzler and gives a good shine with far less effort.
Don’t forget you must use a micro fibre cloth with Greased LightningI also use Fenwicks caravan cleaner and bobby Dazzler but I trying a new one at present Greased Lightning showroom shine and so far impressed
Came with two a yellow and a blue in the boxDon’t forget you must use a micro fibre cloth with Greased Lightning
Ah so they could go green😉Came with two a yellow and a blue in the box
What does each colour do for the cleaning process. I’ve considered waterless cleaners but must admit to being a bit of a dinosaur in that respect. Although if I cleaned cars more often I might be persuaded.Came with two a yellow and a blue in the box
You just spray it and wipe with one cloth and then wipe of with the other i started at the back panel and worked around the caravan it now got a lovely shine but the roof will be washed and polish with the person you pay and he very reasonable .What does each colour do for the cleaning process. I’ve considered waterless cleaners but must admit to being a bit of a dinosaur in that respect. Although if I cleaned cars more often I might be persuaded.
Thanks but what does each colour bottle do. Is one a wash the other a surface polish. Or are they the same but just different coloured bottles.You just spray it and wipe with one cloth and then wipe of with the other i started at the back panel and worked around the caravan it now got a lovely shine but the roof will be washed and polish with the person you pay and he very reasonable .
Coloured bottles? Where did that come from🤔Thanks but what does each colour bottle do. Is one a wash the other a surface polish. Or are they the same but just different coloured bottles.
There only one bottle with a two microfibre cloths one yellow and one blueThanks but what does each colour bottle do. Is one a wash the other a surface polish. Or are they the same but just different coloured bottles.
BB thanks for the feed back. Since your previous post I have been looking at some detailing websites and the common theme is that waterless cleaners are effective on lightly soiled vehicles. . But they emphasise the need to use a good number of high quality 350gsm, or higher, microfibre cloths to avoid scratching the vehicle paintwork. Estimates varied between 12-20 for a car. So get stocks in now for the caravan 😂There only one bottle with a two microfibre cloths one yellow and one blue![]()
After a quick water rinse down do you have to have the car dry before using Greased Lightning?Coloured bottles? Where did that come from🤔
BB has a blue and a yellow microfibre cloths. You can use them for the entire process.
The Greased Lightning does work but if the paint is heavily soiled I’d wash it with water and sponge first.
Yes. But if there is no real visible dirt then it will work well without causing damage providing you use the micro fibre cloths.After a quick water rinse down do you have to have the car dry before using Greased Lightning?
