Caravan Safe
Nov 1, 2005
1,001
I have used a safe in my caravan for a while now Marc, but I believe it needs to bolted through the floor to the chassis or a metal plate. Since the floor is only 6mm ply and polystyrene it wouldn't offer much resistance to a thief.
Sep 17, 2005
29
Only 6mm thick, must be thicker then that. But I am going to put a plate on the underneath anyway.
Marc
Aug 28, 2005
603
Marc can you name the make of you van if the floor is only 6 mm thick, that must be some kind of record !! For the record ours is about 50 mm
MH
Nov 1, 2005
1,001
Yes the floor is generally about 50mm thick, but 38mm of that is polystyrene, with 6mm ply either side, which is what I alluded to but didn't actually say.
