Caravan security
Nov 19, 2006
246
Can anyone advise on what reasonably priced,reliable, security measures are needed to prevent my new pride and joy being nicked. It has an Alko hitch and steel wheels.
Aug 28, 2005
603
Dear Moganic
A lot will depend on how much you want to spend and where you park you van; but for goodness sake get your self down to a good dealers tomorrow to get a Hitchlock, Wheel Clamp at least.
Other things like steady locks are good as is a an "a frame wheel lock". There are loads of good products out there and these are rated by a independent organisation called "sold secure" which the police help set up and continue to run which test products and gives them status.
MH
Sep 14, 2006
264
As monkey said do as much as you can mate, I concreted a post into the ground with a tow ball welded to it. When I park the van up the coupling head goes on the ball with the Alko security device on it and I the have a good old fashioned chain and padlock then passes through the A frame. Not fool proof but will take them longer to nick.
May 21, 2008
2,463
The greater the number of security measures that are visable then the lower the risk of having your van nicked.
Silly things like parking the van front on to the drive, parking your car tight to the side with the wheel clamps on, having a flood light on a pIR etc all distract MR Thief.
You'll never stop a professional, but if you make life to time consuming and noisy to stael your van, he'll ****** off to easier pickings.
Just think of it like this an hour spent un-locking the van means half an hour of risk to a thief and that is a good 20 mins too long as he want's to be gone well inside 10 mins. That's why they carry oxy acetylene cutting gear and use drop boxes. Seconds of delay to them is like hours.
Another little tip is to use anti vandal paint (non drying type) on the wheel clamps and padlocks. Sure, you'll need to use gloves to handle them and carry a spare dry clamp for use on holiday, but just think how many potential finger prints can be left behind, or a trail to follow.
I have a can of luminous paint strapped under my van with a bung in a small hole in the can, which is connected by fine fishing line to the ground. When thiefy tows the van off a litre of paint drips for a good twenty miles and being luminous is dead easy to follow at night.
All you have to do is think like a thief and you'll foil a thief!!
Steve L.
