Collected the caravan last week after 2+ years without one. It towed very well, as I would expect of a lightweight unit. However, it has a nose up attitude when coupled up to the car which isn't a problem towing but could lead to problems with speed humps or ferry ramps. The rear barely clears the drive as I take it on to the road such that jack pads may not be feasible. The Alko chassis is lower than on "standard" UK vans which doesn't help that much. I found a thread on UK Caravantalk going back a few years where an owner had the same van as mine which had a nose up attitude when towed with a VW Caravelle. He fitted the A frame with a spacer plate that effectively lifted the tow hitch/handbrake assembly which is all mounted on a single plate at the apex of the A-frame. What wasn't stated was if it was an official Alko modification. Has anyone heard of such modification to lightweight vans or camping trailers? It's in with my local caravan Alko service centre at the moment being given a health check, so I had asked them to investigate. No surprise thus far other than the Whale water heater element is shot.
The cars tow kit is OEM and non-adjustable. And "regrettably" the Subaru self levelling suspension works far too well and pushing another 70kpa of air pressure into the rear tyres exacerbates the problem. There is no clearance in the wheel box for larger radius wheels/tyres either so I have run out of the easy options.
