caravan tyre protectors
Does anyone know where one can purchase a cover to fit over the wheel arch to protect the tyres. There are already press studs fitted around the tyre area but I dont know where one can purchase them from. Thanks in anticipation
As far as I know most caravan manufactures do not fit press-studs to their caravans, so I have to assume you have bought the caravan second hand. It is most likely a previous owner has used an awning, and the press-studs will be for the awning skirt.
However If you have a good caravan or tent supplier in your area, you may be able to find matching stud caps, and with a bit of cutting and sewing, you could make some covers from covers from a heavy duty ground sheet material.
I have a couple of tyre covers from a guy that sells covers for every thing from hitch covers to tv covers.
I think he trades as bags for ******* (don't remember the last part). He attends all of the big shows.
