Caravan waste drain pipe leak
Jan 15, 2023
13
Hi,
Just wondering if any could advise me on the waste water leak underneath the van where to waste pipes connecting to each other. E32379AD-EB8B-497C-91C9-AD1CE90DFB02.jpegDont think that this is serious but looking for more opinions.
Many thanks in advance
Jan 19, 2002
1,710
551
From your picture it is the join between the flexi and rigid pipe that is leaking in which case I think you just need to replace the rubber connector - and think you need ‘ hose sealing sleeve’ replacement for about 3quid!
Reactions: Daren225
Mar 27, 2011
1,332
507
19,435
If the water was only leaking outside and nothing leaking inside the caravan I’d leave it to leak on the grass, less to empty out of the wastemaster, when we set up I nearly always forget to run a pipe from the waste pipe to the wastemaster.
BP
Jan 15, 2023
13
Many thanks for your reply.
Probably not so easy to find the right one ?
Do you know who sells it?
Jan 15, 2023
13
BP
Exactly 😀
9,509
If you Google Caravan Hose Sealing Sleeve you will get lots of images with dimensions and also suppliers. here's one for example but they don't do online delivery. A local caravan shop will probably have them. You will just have to. check your dimensions but most are standard sizes. Alternatively wrap it in self amalgamating tape.
Jan 19, 2002
1,710
551
I found several examples on Amazon and didn't look further, but surely everything is available on Ebay?
