Whilst I have some agreement with you Reg as regards what could be left off the service list, and what SHOULD be on it, which I will detail later I would like you to think about this.
Today I serviced a 2 year old caravan which has not been used very much, so taking that as a presumption(which I never do by the way)that everything should be in almost perfect condition, there would be little to do .
However, following NCC AWS rules, I removed the hubs to inspect the linings, and what did I find? both brakes, all 4 shoes, the linings were crazed not only horizontally but also vertically across and down the whole width of each in numerous places.
To say I was surprised is an understatement, to say the owner was shocked is also very understated.
With the greatest respect, that damage would be impossible to see through the very small, very hard to get at, inspection hole in the backplate.
It is for that reason hubs are removed, to inspect the bits you cannot see through the inspection hole.
Now, the bit which still annoys me is One Shot Nuts. Ok so sealed for life bearings are supposed to be the bees knees, but give me taper rollers and castellated nuts any day, at least all it costs is a new split pin and wear can be compensated for in setting the bearings correctly.
I may be way off the mark here, but I believe the introduction of One Shots and SFL bearings is because we now have a country of so called "engineers" who have not he faintest clue about how to set bearings and engineering as a whole.
We now have a culture of "fitters", who only know how to change a whole unit and have no idea why , just "that it works".
Now lets go to the service schedule.
One new addition is "Check noseweight",question is WHY????????? and for what use is it?
A van in for service is not loaded as per normal use, it is not attached to the towcar so what is the point?
Checking to see if blinds work,,,why,surely an owner knows this already and will say if there is a problem.
Then on to what really gets me, gas and electric checks.
As you are probably aware, the gas check involves a leak test, fair enough, then checking to see if te appliances light ok and then the stupid bit, to check the appliance is working and is in good order, just looking at the flame, where it can be seen, to see if it is a nice blue colour is all that is required.
What is so bloody stupid is that doing that gives absolutely NO information of any value.
The ONLY way of checking the efficiency of gas appliances is to carry out a Flue Gas Analysis (which is what I do on all vans).
It has been proven frequently that a flame may appear good,but the appliance is producing lethal amounts of Carbon Monoxide.
How many Dealers carry out that check, and give the owner a printed report from the gas analyser? None.
I am not going into the electric side of things as I will say far too much and probably be hung , drawn and quartered by certain individuals.
I will, however, say the subject of PIR's is a thorny issue with me,and many others.
Damp Checks,,,,,,,,IF manufacturers were to do their job properly and have Quality Control, damp would be thing of the past, as it should be in the 21st Century.
Sadly that is not happening,and a damp check takes time, which has to be paid for,,,,,,,sorry.
