Hi
I have a Lunar Ariva 1999 fitted with Carver Cascade.
The flow from the cold water is superb on all taps.
The hot water starts superb, then slows within about 15 - 30 seconds to a trickle. Turning the tap off for about 30 seconds, then turning back on simply repeats the problem. It is the same on all taps.
Also, as the flow reduces, the pump starts to chatter.
I have used a strong solution of tank cleaner twice but it hasn't really helped.
Cheers
Phil
Cheers
Phil
