We have just comeback from our 1st outing this year in our caravan and could not get water to flow from the hot taps, usually once the tank has filled the water runs and we can then turn the heater on to heat the water. I have removed the taps to try and release any possible air block oddly I could only get a small amount of water to flow from the hot tap when the cold tap was running in the wash room and I am not sure if this was just cold flowing in the wrong direction!. It seemed as though no water was entering the tank as I removed the inlet water pipe and tried blowing through the system with the hot tap open but it did not appear that anything was getting through! Any help would be much appreciated - Thanks
