Hi Everyone,
I have a problem with a Carver water heater on our year 2000 Abbey 216, when I run the pump with the hot tap open, nothing comes out of the tap, I can hear the pump running and water comes out at normal pressure on cold. When I open the drain plug to the heater water drains out, if I run the pump with the hot water tap open and the drain plug removed water comes out the of water heater drain. I've taken the pipe off from the out going side of the water heater and nothing comes out when the pumps runs. I have poured a cleaning solution into the outlet side of the water heater and pumped the same solution into the inlet side, as there was quite a bit of, what looked like limescale, that came out when I openend the drain plug. Our van hasn't been used since New Year, but was completely drained down after it's last outing.
Does anyone have an idea what may be causing this problem?
Any advice would be greatly appreciated,
Thanks,
Steve
Thanks,
Steve
