Hi everyone just came home from a week away and have a small problem with the water, I hope you maybe able to help me.
On connecting the water and bleeding through the taps as usual, this time the pump would run for a second or two every min or so.
I thought this maybe something to do with the pressure switch that is situated just inside the van by the pump, I thought it might have got moved as the outside locker door is used a lot to put things under the bed from the outside. With the weather being so crappy I said to my other half it can wait as we had water. Then my pump light would stay on with the pump running, so I turn pump off from the wall as I thought aquaroll was empty, but it was a good half full ( a 40 ltre) so I topped it up anyway switched on pump and the water came through ok, but still the pump would run every min even though the taps were shut, as soon as aquaroll was down halfway pump would stay on.
Looking through everything I can find no leaks, we had ehu so power was constant although battery is new tried another pump no change.
Now we are home I will set it up and see if I can find the problem, but am hoping for some pointers I dont think my taps are microswitched but as I say will have a good look when I`m off.
Caravan is a 2002 Coachman Amara 530/4
