carver water system problem
Aug 23, 2009
23
I have the carver water system in my caravan. when I turn on the sink taps the washroom taps drip, then when I stop the tap the washroom taps drip a bit heavier, then stop..
What causes this? and how can I stop it...
Its the shower head on the hose type tap in the washroom
4,465
HEllo Shaun,
From your description, your pump is controlled by micro switches in each tap. so when you turn on a tap the pump is powered and it pressurises the water system.
The problem you have is that the taps are not closing/sealing properly.
4,465
That depends on the make and age of the taps. Your best bet is to seek advice from your dealer.
