Hi, I wonder if someone could give me a bit of advice about using my water system! I have an Abbey Oxford, 1991 and have just had a practice run at connecting the fresh water. However it's a bit tight on that side to connect my aquaroll and it's up against my neighbours wall, so I filled a bucket and put it on top of the wall. Connected the pump to the inlet and it started running straight away, so I unplugged it and went inside the van to make sure all taps were closed and the 12v was off. Tried connecting again and it ran again so I popped it in the water. It started sucking away so I went in again and switched on 12v and turned taps, which flowed happily, so turned them back off. When I went back outside I heard dripping water and presumed it was the waste but it was the drain on the Cascade open. So I closed that, but still the pump was going and some water was still coming from the drain plug. I didn't light the heater as I wanted to get the connections right first. Could someone please explain how it works and what I'm doing wrong or is something broken? There was a kink in the hose due to the position of the bucket. Help! I'm going away for the first time in 2 weeks!
Cheers all
John.
Cheers all
John.
