CBE / C-Line switch for outside light with led display
Hi
I'm trying to find an alternative switch that has an led display that shows when it is on.
i currently have this switch:
But i always forget that the outside light is switched on. and wondered if there was an equivalent that has a small led that shows when it's switched on - rather like this one (but not a rocker switch, and showing inside and outside light images)
almost like this (LED indicator photoshopped on to image):
I know i can get this one image.png.dab31afdf47b493e03e4d7c208ea14ca.png or this one image.png.68bdb3d522e442b056602b6933f161de.png
but that is one switch that will take up the space of 2 and doesn't indicate what it's for.
  • Is there just a C-line/CBE LED indicator that i can wire up to be on when the outside light is on?
  • Has anyone done anything like this?
  • Any other suggestions that will help remind me to turn the outside light off?
(ps, I've posted this query in other caravan / motorhome forums, to get a wide opinion)
Can you not just drill a hole and fit your own led?
Easier and cheaper than replacing the switch.
sooo, i have purchased LED light (min order 10, but for £3 inc postage, i live life on the edge and thought 'why not?'!)
i will let you know how i get on. If the Royal Mail is working well, they should be here for the weekend playtime 😀
Reactions: Mel
Sorted!
3mm pre wired LED from amazing 👌 [the ones from feabay were incorrect💩]
3mm hole drilled into switch unit.🔎
Live wire connection to on side of switch wire
-ve wire connected to the -ve wire of the outside light.
Outside light switched on, led is on. Outside light switched off, led off 🥳
(Note, the LED isn’t as bright as the photo makes it appear)
Happy days 💡😁
Sorted!
View attachment 10417 View attachment 10416
Happy days 💡😁
Guid job 👍 remember and switch it off!
