Hi all
Just returned from trip with battery problem,had to use switch on main panel to turn off water pump. when nothing switched on meter needle stayed on green, turn pump on and it went nearly to red and the pump stayed on, hence switching it off on the panel, the needle then returned to green.
I did use a battery charger to fully charge the battery before our previous outing and had no problems.
The question is, as I am having the battery tested tomorrow can it simply be replaced with the 110AH and what are the benefits if any?
Any response will be greatly received thanks in advance,
Kev
Kev
