Hi all, I have a 1994 Sterling Emerald, what is the easiest way to change butane to propane as we are away in the winter thanks for any info.
You will need a spanner; note the connector is a left hand thread.Clearly you have to aquire a cylinder of Propane. Then assuming its for the UK then at your vintage van all you need to do is buy and fit a propane[ red] regulator. Propanes in our UK leisure world all share the same thread/connector. Best also to buy some new hose if yours is more than 4 years old from date of manufacture; its marked on it. I would only buy the red one myself.
Why onlr red hose?Clearly you have to aquire a cylinder of Propane. Then assuming its for the UK then at your vintage van all you need to do is buy and fit a propane[ red] regulator. Propanes in our UK leisure world all share the same thread/connector. Best also to buy some new hose if yours is more than 4 years old from date of manufacture; its marked on it. I would only buy the red one myself.
Although in todays climate of equality you probably would not be Courts MartialledYou need to keep away from inspecting other people's hoses. I had an Adjudent warn me about guys like you.
