Changing from Butane to Propane - how???
I'm changing my van to run Propane rather than Butane, is it just simply a task of changing the regulator?? or is there more I need to do??
Jim
If you have a 2004 or later van with fixed bulkhead regulator, just change the pigtail for a propane one.
If you have the cylinder mounted regulator, just change that for a propane one.
Nothing else to do
JimP
Depending on the age of your Caravan, if it has a 30Mb Bulkead mounted regulator, then you only need to replace the Pigtail with the relevant Bullnose type for Propane. If however the regulator is a cylinder mounted type, then this will have to be replaced too,
best regards, Martin
JimP
sometime waiting for a reply on this forum, is a bit like waiting for a bus, two come along at the same time.
