changing water heaters
4,062
Hello Colin,
The Carver cascade 2 is no longer manufactured, so you would be hard pressed to find one that was guaranteed. There is a model called a Henry which is almost identical to the Cascade, but the majority of caravans are now fitted with the Truma boiler.
None of the models are a direct replacement for the Maxol, so some engineering will be needed to fit which ever morel you choose, but for your safety have all the work done by a competent gas fitter.
46
19,185
Not heard of a 'Maxamol' so will go with Johns thoughts and assume you mean a Maxol Malage?
If so then The Malaga is now made by Propexheatsource.co.uk
Identical so a new one will fit straight in, or spares are compatible and having recently fixed a leaking Malaga, I can say it's a very straight forward job.
Feb 27, 2010
14
thanks and sorry about the spelling before. i have desided to go with the new replacment from propex is the electric's and plugs the same. thanks again
46
19,185
No, the heater should be a direct replacement but there are various minor differences including wiring connections, also the control switch and it's loom, all problem arising though should be very easily overcome
