- Feb 3, 2008
- 31
- 0
- 0
Hi
Please forgive my inexperience......brand new to caravanning and want to get it right before I actually do my first trip.
In my instruction manual regarding the electric settings it states to place the 'Car-Off-Van' Selector Switch on the electrical distribution board to 'Off' (central position) for travelling.
1st Question - It isays "When in the central (off) position....with the 'charger' switch 'on' power is provided to all 12 volt circuits via the 'transformer/charger' unit". Am I right in assuming therefore that in the central position, this power would only be provided by the transformer/charger unit if it were connected to a 240v mains supply.
2nd Question- Regarding the 'charger' switch it states' "when the van battery requires charging press the 'charger' switch to the 'on' position and ensure the Selector Switch is in the 'Van' position". Again presumably this is only when connected to a mains power supply. The reason I ask this, is that someone suggested that the transformer may work similarly to an inverter, and invert the 12v power from the battery to 240v to 'charge itself' so to speak, but I'm not sure that's right is it? The other confusing information in the manual is that at a different point it says, ""When the selector switch is in the 'Van position, dc power is available from the caravan battery to power all 12v electric circuits. If the charger is switched 'on' the caravan battery will be charged via the transformer / charger unit".
3rd Question - When travelling, does the power from the car, charge the battery on the Van via the 12S connection, (as i beleive it may) and is this powerful enough to provide an adequate charge or is it merely a small trickle charge.......if at all. I ask this because it states that the selector switch can be placed in the 'Car' position should the caravan battery become discharged and no mains power is available, but the van must be connected to the car via the 12S socket.
I'm sure those of you who are seasoned caravanners know exactly what the manual is saying but to a newbie it can be confusing when the manual makes assumptions that you know what does what.
Any help would be gratefully welcome......
Thank you......Sizzler
