charging my fridge while towing
hi i have a compass corona 626 club with a 13 pin plug my tow car has the 7n and 7s plugs i bought an adaptor to fit and it seemed to work ok. i have found a proble that whie i am towing the fridge does not charge, on reading a few web sites it says that pin 10 on the new plug charges the battery or the fridge does anyone know how i can make this charge the fridge only or can i make it charge both all advice would be greatfully accepted cheers
Whilst towing with your car, it will only charge your leisure battery......
It does not charge the fridge ..........
The fridge only runs on 12v when the tow car engine is running.....
Have a look in your caravan handbook to see what needs switching over.....
Have a look here at the 13pin wiring diagram
Please be aware that some manufacturers adaptors
don’t provide the fridge power connection...........
Check the one that you have bought !!!
FOUND OUT WHAT WAS WRONG ONE OF THE PINS ON 7S SOCKET ON CAR WAS BURNT OUT HAD 13 PIN SOCKET FITTED CHARGES FRIDGE AND BATTERY NOW IF PIN WASNT BURNT OUT SHOULD HAVE WORKED OK
