Weight of caravan on driveway
We are moving house and putting the caravan on the driveway, which is paved, and the whole area is built on sand - I'm concerned the weight of the van will partially sink some of the flagstones that the wheels rest on.
Would putting down a good length of wood under each wheel displace the weight to reduce this, or are there any other ways of reducing this, other than getting the area strengthened from underneath?
Seems to be inviting a lot of unnecessary hassle, I would be inclined to get any dipping corrected if it ever happened to an extent that caused real concern.
Pavers are typically set on a compacted sand base, though I do believe it has to be the "right" sand which if laid professionally should have been used. Issues could come if water run off was not designed in.
On the heavy traffic bit of our drive, road traffic on our lane use our apron as a passing bit, here the contractor mixed dry cement into the sand mix in that particular bit and it has taken lorries cars etc for a decade without sinking.
Our daughters house drive has heavy concrete slabs and on occasions I used to park the caravan on her drive and there was no discernible effect on the slabs.
Any driveway, designed for vehicles, should be capable of supporting at least 3500 kg vehicles with unequal axle weights - so it should be ok up to 2000 kg single axle or any twin axle - but whether your driveway is built to that standard is a question for the builder/contractor.
The original owners of our house had the driveway widened back in the '70/80s- but when I parked my Vauxhall Senator there, only 1500 kg kerbweight, the tarmac started to sink - I guess not sufficient foundations.
All depends on how good a job was made of laying the paving slabs. I would think that if its been used for a while as a driveway there shouldn't be too much of an issue. Of course a caravan will be in exactly the same spot for a considerable length if time whereas a car will be constantly move, and probably never left in exactly the same spot each time.
My advice? Suck it see!
I had a block paving laid , all good but looking at it after two year, it has sunk, bye maybe 1/2 inch, where the vans tyres sit. Not overly bothered. The front door of the house needs new painting first.
How long has it been laid? As said by Mr P if it’s had cars on it……
I suspect beneath the sand will be a decent hardcore base. Sand is used for the final levelling and if been down for a while I suspect any settlement will already have taken place.
.....remember a single axle caravan will have a tyre carrying twice the weight of a car tyre on average.
I recently had some block paving carried out and was interested to learn that expert contractors now don't use any sand.
They use coarse grit for the levelling layer which I'm told alleviates any uneven settling.
Mmmmm, so when does sand become grit???
It rather depends on where you live. There are many grades of sand identified by granule sharpness, size and cleanliness. Also pit or sea,
Sand in general is an excellent medium, regardless of grade, so long as it is contained and compacted before screeding.
I have generally used sub base as the foundation material then a layer of sharp sand, then cement mix. Some use ballast as the foundation layer but it doesn’t bind as well as sub base.
