complete novice
Hi All, I am going to start looking at caravans this weekend. I know some questions to ask the dealer, I am really concerned about damp. Would it be wrong if I took a damp reader with me? What do most people that buy second hand do?
Some dealers might object to a damp meter with prongs. Ask to see service history and if it’s been carried out by dealerships or AWS then a recent one should give a good indication. But mainly you can’t detect damp by smell or sight until it’s got a hold. If there is a van you are really keen on you could buy a AWS or MCEA inspection survey. Dealer should not object to that.
We can also advise on purchasing options tyat maximise your rights under UK Consumer law such as CRA2015, CCA etc.
First off ask for any service reports including damp reports the dealer has .Often the damp report may only have 'ticks'which doesn't tell you much. Look at the front windows , particularly behind the curtains, inside the cupboards some caravan wallboards turn a light shade of blue if damp Also look for tiny pinpricks where a damp meter has been used. Around the windows lift the inner lip of the black window seal and look at the plywood colour if it black then its damp and starting to rot. More modern caravans have woodless' walls and roof but the floors may still be plywood , look underneath the front and rear corners , looking for spongy or damp wood( to the touch). Look at the front and rear panels ,where they attach to the sides , looking for hairline cracks.Test all the systems don't take their word and get a warranty off them in writing. If in doubt walk away , its a buyers market at the moment
I think that a damp meter is only going to be of use to you if you know how to use it, and where to check in the caravan. In addition, as has been already mentioned, the dealer may be concerned if you turn up with a pronged damp meter and do not appear to be experienced in using one.
If you are a complete novice, as you suggest, it might be sensible to ensure that you are dealing with a reputable dealer, and look for a caravan with a good service history which includes damp tests. Make any purchase conditional upon having the caravan inspected by an independent caravan technician.
I would go with a pin less meter I the dealer has any beef with it ask them to go around with their meter.
Otherwise walk away. .
