Weight of caravan on driveway
We are moving house and putting the caravan on the driveway, which is paved, and the whole area is built on sand - I'm concerned the weight of the van will partially sink some of the flagstones that the wheels rest on.
Would putting down a good length of wood under each wheel displace the weight to reduce this, or are there any other ways of reducing this, other than getting the area strengthened from underneath?
Seems to be inviting a lot of unnecessary hassle, I would be inclined to get any dipping corrected if it ever happened to an extent that caused real concern.
Pavers are typically set on a compacted sand base, though I do believe it has to be the "right" sand which if laid professionally should have been used. Issues could come if water run off was not designed in.
On the heavy traffic bit of our drive, road traffic on our lane use our apron as a passing bit, here the contractor mixed dry cement into the sand mix in that particular bit and it has taken lorries cars etc for a decade without sinking.
Our daughters house drive has heavy concrete slabs and on occasions I used to park the caravan on her drive and there was no discernible effect on the slabs.
