Cleaning Alko Hitch on Caravan
I read lots of pople saying to clean the Alko hitch lock on the caravan but how to you do this without damaging it
Dray cloth, wet cloth, hoover brush ??!
Dave,
It depends how badly contaminated the tow ball / tow coupling have become.
Starting with the tow ball - if you don't have a detachable tow ball, your fixed tow ball may be a bit rusty - so a rub over with a green scotchbrite pad will clean the rust off.
Then wipe with a clean cotton rag (old T-shirt material)
If for some reason you think the tow ball may have a bit of grease or oil contamination - wipe with a cotton rag dipped in some white spirits or brake cleaner.
Then the tow coupling - inside the tow head (of an ALKO or Winterhoff stabiliser coupling) are a pair of brake pads that grip the tow ball - the surface of these pads needs to be clean and contamination free.
Wipe the surface of the pads with a clean cotton rag (or kitchen paper) - just make sure you don't transfer any grease by using an old rag.
Take a look at the cloth - it may have some black powdery deposit - this is normal. Keep wiping until the cloth comes away clean.
Robert
