Just reading on google some say it's best to get all paint of towball if using a alko 3004 stabiliser hitch.should I be doing this ? Hopefully picking up a van next weekend
Marbles007 said:Just reading on google some say it's best to get all paint of towball if using a alko 3004 stabiliser hitch.should I be doing this ? Hopefully picking up a van next weekend
kMartin24 said:Don't forget to keep it clean with a quick rub over with fine emery and then a quick clean with brake cleaner. I do it pretty much every time we hook up.
If you don't remove it, the paint will gradually wear to a powder, which then embeds itself in the friction pads, causing glazing. As others have mentioned the pads own dust has to be removed from time to time, as this causes glazing too, leading to groaning sounds.Marbles007 said:Just reading on google some say it's best to get all paint of towball if using a alko 3004 stabiliser hitch.should I be doing this ? Hopefully picking up a van next weekend
