And who exactly is ever going to see it? Other than you when up a set of step ladders of course.It's a bit green under there.
Exactly, or if you roll it on the motorway.And who exactly is ever going to see it? Other than you when up a set of step ladders of course.
Try some Fenwicks Caravan cleaner that should remove itIt's a bit green under there.
Don't worry, the streaks will be black. 😉Don't want green streaks down the side of the van when it's raining, or on my awning.
Wouldn't recommend using it as some of these outdoor cleaners are quite corrosive.If it's green, just spray some Patio Magic under there and the green will disappear after a few days. Same goes for any green on awnings etc.
I've been using it on the covers on my boat for over 10 years, with no ill effects.Wouldn't recommend using it as some of these outdoor cleaners are quite corrosive.
Boat covers aren't caravans. Wrong product can break down seals, cause galvanic reactions or corrosion of some metals directly. This can be even worst if product is designed to be sprayed on and left. The few $$ saved by not buying caravan specfic product could cost lot $$$ long run.I've been using it on the covers on my boat for over 10 years, with no ill effects.
The only caveat is not to use it near watercourses, hence I always did the covers at home.
There is another product called Algae Zapper distributed by Kinver Canopies, who make boat covers, that is exactly the same but four times the price.
I wouldn't recommend something that I haven't tried and tested.
It has to depend on the caravan as well. I probably wouldn't use it on a new £40k caravan, but on my old van with its collection of battle scars I'd be tempted to give it a go. Just test on a small area first.Risk aware, risk averse. There's a big difference!
