Hi,please can anyone tell me the best way to clean the water pipes in your caravan and what to use? And is it the same for waste pipes?
Many thanks Steve
Many thanks Steve
Thanks everyone. Have used Milton looks like it worked, will have a look at Kemdirect cleaner may get some for next time.Hi Steve
You can use the products mentioned above but you will get and after taste from many of them and they will only do half the job.
If you use Kemdirect cleaner / descaler you will remove both the germs and bacteria and the calcium build up ...if any.... where many of the germs live.
With some of the products suggested you will not remove scale as they are not descalers only cleaners.
Kemdirect is completely biodegradable and leaves no taste after rinsing the pipes or tanks etc.
You can use it safetly throughout the caravan both in the drinking water and waste water and then take it into the house and use it as a pure descaler in kettles, shower heads etc. Here you can actually see it working.
It is available from www.trail-a-mate.com as mail order or through some dealers and suppliers.
Hope you find a product that you feel safe with and does the job.
Joyce
You can't get chempro SDP any more. Out of production I'm told. There are other similar products, but Milton is a no no due to corrosion possibilites.Further to Ann's suggestio nalso make sure you flush out teh milton solutoin from the caravan pipework + heaters as well. Milton is basically bleach and will eventually corrode metal fittings if not fully washed out.
Alternativley use a brewers cleaner such as Chempro SDP, which is compatable with metals.
