clear roof light
May 15, 2007
471
Today a mobile fitter came and removed the roof fan from the kitchen area and replace it with a clear light, what a difference, i now have light in the middle of the van!!!!!!. I never used the fan and it stopped a lot of light coming in . Wish i had it done years ago, good job at a good price.
3,243
I was dissappointed that the fan was an extra-cost option on the Clubman as we wouldn't be without one !!
Feb 3, 2008
3,790
We had a fan fitted as a costed option when we bought our van. Essential to clear the heat when the oven is opened and sets off the smoke alarm. ;)
3,243
xtrailman said:
One mans meat...
I wouldn't want one again, too noisy and not very effective.
The fans I've had have only been noisy on full speed - which is only used for a short time when the caravan's been shut all day in a heatwave, very effectively too - it's normally only used on the 2nd of 6 fan speeds.
Like WC, we use the fan when cooking to clear excess heat and stop the smoke alarm activating.
May 15, 2007
471
Some interesting comments, I found that not only did it block out the light , but when i wound up the vent it would only open one way. If there was a breeze from the back of the van no matter what speed the fan was on it was blowing back into the vent. With this new light i can angle the light so it opens down wind therefore sucking any cooking steam etc away. Nice to hear some people still have a battery in the smoke detector, i find most people take it out as it goes of all the time.
Feb 3, 2008
3,790
As a safety practitioner I consider removing batteries from smoke detectors VERY foolhardy.
3,243
That's worrying - but given human nature I'm not surprised.
We have working smoke detectors in every room of the house, except kitchen and bathroom - all regularly tested and batteries changed as appropriate.
Jul 15, 2008
3,860
1,017
.......there is a simple modification that can be used to make a smoke alarm more user friendly in a caravan environment.
You simply fit an on/off switch mounted on the outer casing.
I only have the smoke alarm turned on when we are actually sleeping in the caravan so it is turned on last thing at night and off first thing in the morning.
I have paired these actions in my head with locking and unlocking the door so never forget .
Turning the power to the alarm on also puts the alarm through an audible 2 second test sequence so you test that it is working every night.
I used a Sub mini toggle switch from Maplin.........drilled a hole through the plastic casing where it would fit and be convenient to operate..........cut the positive feed wire from the battery and connected it to one switch terminal...........connected the other switch terminal to the positive feed wire to the circuit board.
No more false annoying actuations during the day whilst still maintaining safety at night
.............and the battery lasts forever!
1,818
We did have a fan in our Eldiss and found it useful. It was quiet enough on the low speed which gave enough air movement to keep the temperature down provided you used a higher setting first. We had a second roof light so never had a problem with it not letting light in but it certainly was of no use for that.
As for the battery in the fire alarm even coming from a safety background I am not keen on them. I do find it difficult to believe that if the caravan catches fire it will not wake you up just as quickly as the alarm but having had one imposed on us we do keep the battery in.
Mar 30, 2012
41
5
18,535
I replaced mine with a clear one much better as you say.
I fitted the fan one in the toilet replacing the grotty uncleanable original.
jiginc
3,243
jiginc
Where did you pick up a 12v supply for that? I'd like to fit an extractor fan there as well.
Jan 3, 2014
131
We have a fan in our van and wouldn't be without it, every time we cook it gets switched on and we have just ordered a new van and that has one as well.
spardoe
Administrator
May 12, 2010
81
Hi Graham,
Stacie here on the Practical Caravan team, hope you're well? I'd like to use this post as a short letter in the magazine and just wanted to check if you're OK with this?
Kind regards, Stacie
3,243
jignc said:
Supply was from a downlighter over the wash bowl just outside the toilet.
jiginc
Thanks, I need to get busy over winter - I'll add that to the list.
