Stephen - I apologise for my error in the given values for the Wheel studs and nuts - you are correct in your figures of
Torque Settings for:
Steel wheels 65 lbs/ft (88Nm)
Alloy Wheels 85 lbs/ft (110 Nm)
Regards
Stephen - I have in front of me their 2006 Models Technical Specifications for the following model and it clearly states and I quote
Tyre Pressures (at quoted MTPLM)
Amara 520/4 62psi /4.3 bar
Pastiche 520/4 60psi / 4.1 bar
VIP 520/4 60psi / 4.1 bar
whilst I accept that you have found that running your caravan at lower pressures are ok for you, I will be running my caravan at the figures given by coachman in their specification booklet, until I have your figures supported in writing and I will be writing to them on the matter. I would hope that you are not thinking I am doubting your information here but if yours are correct I would hope they will withdraw the current specs and issue a addendum to the manual. Regards FKG
