Compass Conoisseur 440/2 battery charging
Sep 26, 2009
Can anyone tell me if the above 1997 caravan is fitted with a battery charger as standard to charge the lesuire battery when the van is connected to the 240v mains. The reason I ask is that I can not identify a battery charger unit and there are no switches or gauges to tell me the state of the battery or if its charging or not.
Thanks for your help.
199
19,235
Most probably you do have a battery charger. Turn on all your caravan's interior lights with the mains lead disconnected, then after a while get someone to reconnect. If the lights brighten somewhat, the battery charger has kicked in.
199
19,235
Further to the previous post, if you have a multimeter, disconnect your mains lead from the van and take a reading across your battery terminals. You should have a reading of around 12.8 or so. Now connect your mains lead and if your charger is switched on, the reading across the terminals should jump to around 13.8
Jun 11, 2012
1,536
33
19,685
Mark Im not 100%sure but you may well find your battery charger uder the front seating of your Compasss, try under the near side seat that was where I found ours on our Compass but as I say not 100% on this .
I had a similar thing on ours ,new charger was
Jan 10, 2007
33
