Concerned over new tyres
Apr 20, 2009
5,642
1,053
Had new continental vanco tyres on the van a couple of weeks ago.
Took the rims to garage and had the tyres fitted, got them home and put them back on
Asked for 65lb pressure and getting the van ready today thought i would check the pressure
to see if they had lost any.
They are up at 75lb!!!!!! Clearly states on tyre PSI 65lb!!!!!
Will there be any damage as they are over inflated?
When do you re-torque the bolts, aluminium at 115lbs have read two differant bits of advice
a) After 24 hours
b) After 10 miles
Havent used them yet on the road.
Apr 7, 2008
4,909
Kev
My tyres run at 63psi & the tyrepal shows them go right up to 75psi when towing & they get hot.
I only noticed this when i first used the tyrepal system, I got in touch with Dunlop & was told that that was normal.
When we just went up to Scotland you can see the pressure altering due to driving conditions, Oh! & the weather conditions alter the tyre pressures.
Don't think there will be any damage...
As to re-torquing your Nuts
I thought 30 miles or half an hour rings a bell.....
But if you want to check them after 10 miles that could be half an hour
Apr 20, 2009
5,642
1,053
This caravanning lack is getting too stressful
Check this check that then double check it
Thanks for that Sprocket will let the tyres down tomorrow night if they read the same quite warm here today.
Will do me nuts at Exeter Services 20 miles from home, proberbly the best place to stop before we hit the M5
4,465
Hi Kev,
The pressure rating on a tyre is the static pressure, and it will include a considerable marging to cope with a tyre is driven over a bump or put hole which will cause the pressure to spike at a much higher pressrue.
Jun 11, 2012
1,536
33
19,685
Now Kevin two problems solved together here your tyres and why everything jumps off your hanghers in the wardrobe..... tyres are too hard .. good night .
Sir Roger
Apr 20, 2009
5,642
1,053
Sir Roger
[/quote
