my bailey has cracks on front and rear panels has any one had them repaired with plastic welding if so any good and who from.
Just because its in warranty doesn't mean that the replacement is a brand new one - it might be a refurbished one, or even your old one repaired!Thanks for that Read Caravans.Good to hear from experts outside of teh manufacturers.
Did you discover the main cause of the cracks?
Was it inbuilt stress loads at the time of manufacture ?
I have heard some of the manufacturers screws were wrongly installed without spacers. Is that the case?
It's good to know successful repairs on out of warranty caravans are possible. As mine is still within warranty I think I'd want the panel replaced if it failed.
Dustydog
Whatever happened to the word Faith?Thanks for that Read Caravans.Good to hear from experts outside of teh manufacturers.
Dustydog
Hi, Repair methods depend entirley on the type of plastic used, some repair well with adhesives, some with hot melt some with fusion welding, providing the correct method is matched to the correct type of plastic there is no reason why a repair should'nt last as long as the original substrat.Can Read Caravans tell those of us who have been affected by this issue how the cracks are repaired - not in a full technical sense obviously, but just 'in a nutshell'.
The reason for asking is that when I had this problem I was given all sorts of conflicting advice. Firstly I was told that plastic welding was only succesful in the long term if both sides of the panel could be accessed - in my case this would have entailed removing the panel anyway.
I was also told that adhesives were not a long term solution anyway BUT things may have moved on in the last year or so.
Grtaeful for the comments by Reads - nice to have someone who seems to know what they are talking about on this particular issue.
