- Oct 17, 2010
- 1,329
- 576
- 19,435
First class job Dave.
Really great job. Did you manage to place reinforcing at the back of the crack. If so how and what what ?
Well done Dave, that is a brilliant piece of craftsmanship. How did you get the colour match, paint or gel coat coloured? Was your panel,ABS or GRP?
Thanks.
Looked worse than it actually was.
It is ABS (smooth back) and the back had been pushed up and over the inside piece, toward the awning rail and I had to carefully prise it back, it actually clicked back into position very easily, (could breath again) the bottom corner was in, three larger piece's that were still attached, plus a few free pieces, none too small, that could be used.
I knew I had to reinforce the back, as sticking ABS by the edge, is not a good Idea. Bought some two part epoxy resin (something WELD ?) that is used on bike fairings, it has a very short workable life.
Then I laminated some those plastic plant markers, cut them to about 1 1/2" long, then tied the m too a length string. Then I wedged the split open again, covered the plastic in resin and threaded them though the split and pulled them gently back flat against the inside across the split, removing the wedges making sure the two side lined up, one at the bottom of the split, one about half way up, I got another through the hole at the top. Got another support in the bottom, then it was like a jigsaw hoping the resin had enough grip to hold it as it cured, which it did.
Then filled everything with resin, making sure it was push through to the inside.
Had some P38, then I filled, sanded, filled again then sanded again. Sprayed with filler undercoat, then sanded it again, all with wet a dry.
My lad got the paint, which matched almost perfectly, can't remember what it was called, it certainly wasn't Halfrauds. although the filler under coat I used was, the Orange/Grey stuff.
My big worry at the time, was that I had not got enough support at the back, but that was three years ago. So Far So Good.
Thought showing it would encourage the OP to have it repaired.
