cracked shower tray
hi,
repair usually is not an option,best way is to replace it,with weight been put on the tray when in use any repair will be the weak point and very rarely works.this is usually caused by packing underneath the tray either shrinking under pressure or inadequately packed out.can get replacements and can get stronger trays to original.will cost around
Apr 28, 2009
13
hi rodney, repair is an option because i repair shower trays with cracks every other week. first of all we drill a hole at each end of the crack then spray the whole shower tray with a rubber sealant.
May 21, 2008
2,463
Hi Rodney.
There is always a way out of any problem so long as you work at it.
I have a 2005 Abbey 540 which had two cracks in the shower tray by the loo. As the van was out of guarantee and a new tray which is available via Swift was
hi derek
just wonderin how much you charge for the average repair.
also the diy side of this is possible as has been said,but not many caravanners are as competent as leo, and, depending how the crack is repaired___it is a weak point.have heard of numerous repairs that have failed,but i suppose thats down to the repairer.
hope you get the repair sorted rodney____see what leo and derek say___they might just help you out.
May 21, 2008
2,463
Derek's repair is ok to do, but from what he has said there are two draw backs.
1/ The reapir would be visably detectable and as such would de-value the van.
2/ Without taking the tray out you cannot be sure that there is no underlying delamination or rot tat may of caused the problem.
To be able to see my repair, you would (A) have to know where it is and (B) have to use a magnifying glass to find it. Even the fillet of sealant looks like it is intended to aid water run off rather than hide a deliberate cut to the shower tray. Had I of not beein living in the van, I would of taken the loo out and got the tray up in one piece.
I'd shudder to think what sort of bill you would get at a workshop for this job but based on my own rate as a self employed engineer, it would workout at
May 21, 2008
2,463
