cracked shower tray
Sep 11, 2005
67
I am looking for advice on how to repair a cracked shower tray in my Swift caravan,it has been suggested that Bondloc epoxy resin or plstic weld would do the job has this product been tried by any-one ? if so would I need to paint it after ,if so with what? any help welcome
thanks Rod
Nov 5, 2006
805
Hi Rodney,Fraid I can't help with the repair as most adesives are not adequate for such repairs,& the crack should idealy be "welded". This problem is usualy caused by the compression of the foam layer underneath the tray.If nobody else can help perhaps this company can help http://www.panelworks.co.uk/
SBS
Mar 15, 2007
210
What model and year of 'van. May be able to point you to a source of GRP trays.
Mike
G
Guest
By the way, if it has cracked around the drain hole, then crawl under the van and look to see how big a hole Swift have made. It is usually the case that it is much larger than it need be, and the drain is hanging in open air, so when you stand at that point. the plastic cracks. Even if you repair, or replace, try to fill the hole. I installed a sheet of steel with a hole just large enough for the drain and the tray sits on this.
May 21, 2008
2,463
Hi Rod.
I had a cracked shower tray in my Abbey 540Se (swift group product).
I had to take my tray out for repair as it was cracked between the ribs on the floor of the tray. The cracks (2), were about 6-8 inches long.
To avoid having to take the toilet out to get the tray out in one piece, I made a cut with a dremil type tool along the small lip between the top of the tray and the loo base part of the tray. This lip is covered by the shower door when it is in use, so unlikely to suffer from leakage. It does take a few hours to extract the tray carefully avoiding further damage.
The root cause of my cracks was the foam board packing piece that is supposed to support the tray base. Having removed that from the tray I then claened the underside of the tray and key'd the surface with coarse sand paper. Now using a glass fibre kit from halfords, I glassed over there repair using three layers of glass mat over the crack and covering about 2 inches beyond the cracks all round for support.
The after the resin ahd set (overnight), I used 3 tubes of bathroom sealant to fill all the undulations on the underside of the tray prior to putting the foam pad back, using the sealant to bond the foam to the tray.
Then it was a simple task ( another couple of hours) to re fit the tray.
Finally I sealed the cut I had made with a bead of sealant that converted the step from the tray to the loo stand (10mm) into a 45deg slope to allow any water to run off quickly and not hang around the cut I had made.
This repair was made about four months ang and has stood the test of time without any sign of failure, despite us living in our van full time. And it is still virtually invisable, you would need to know where the repair is to spot it.
One tip I would offer is to put masking tape on the cracks on the smooth face (the side you see when fitted) to reduce any rezin bleeding throught the cracks.
Sounds complicated but so long as you are a competent DIYer and have a spare weekend it can be done. Saving you
SBS
Mar 15, 2007
210
The shower tray in our 2002 Eccles was also cracked around the sink hole. I removed the swivel loo - an easy job - four screws under the loo and two to remove the filler and removed the tray which was stuck to the floor using non-setting mastic. Upon removing the tray I found that as well as the drain hole cracks, there were numerous cracks all around the panel - a problem common to vacuum formed plastic panels.
I had a replacement made in GRP. Although it is a little heavier than the original tray, it is much stronger and, I believe, will last a lot longer.
Again using non-setting mastic on both the floor and foam spacer, I refitted it, screwed it down and resealed with silicone and then replaced the toilet and resealed it.
It has been in for just under a year and looks as good as, if not better, than the original.
Mike
