cracks in windows
hi everyone
does any one know what causes hair line cracks in plastic windows they all start at the top of window and run down a few inches then stop any help would be good thanks danny
Do you happen to have a Bailey Series 5??
We have a Ranger and have had to have all the windows replaced twice due to a fault!!
Most annoying!
Sally
Daniel,
Hairline cracks in acrylic or polycarbonate plastic windows are stress cracks - the direction of the crack points back to the region causing the stress.
So if they point back to the hinge mechanism - that implies that the full length hinge isn't straight or there is some other issue placing a load on the top of the window.
And these cracks don't stop - they'll continue to grow with time.
If it's a warranty job, then make sure they are replaced and (more importantly) the cause rectified.
If the cost of repair is down to you - then you could try Captain Tolleys Creeping Crack Cure - it should draw itself into the crack and both seal and stiffen the cracks.
Robert
