We have just been away in our new Crusader Super Sirocco for the fist time. Just picked it up last week so still feeling my way around it at the moment. Does anyone have a 2007 Crusader with an onboard water tank and the new style Truma external pump. I wanted to use the aquaroll without the onboard tank so turned the valve at the tank to close it. Then on the control panel turned the switch to external pump but after the hot water tank had filled turned the tap off but the pump just kept running (all drain taps shut). The tap worked fine but the pump would not stop. So in the end we had to fill the onboard tank and when full the pump swiched off and then we used th internal pump with no problems. So does anyone know if you can use the aquaroll without having to use the onboard tank each time. Appreciate any replies
Lee. C
Lee. C
